Add a tourpack and/or slip the clutch and it can be done on any bike....Mine does it with a throttle snap in first like nothing...I ran a packed up tbag on my bike for a short road trip and it was like i shed 100 pounds off the front end..
Looks like you engine is not stock and 117 is way bigger than 103. Plus without tour pak on could people do one with stock engine or light mods
you can do it on a stock bike--it helps to have a loaded tour pak. Get the revs up to 3500 - 4k rpm -- ease the clutch out just before it grabs lean to the back let the clutch go and give it gas -- this has to be syncronized (sp)
Much easier do it with a built motor -- my 107 has no problem getting up in the air--my former 103 could get up also but I had to manipulate the clutch--
