Need help re-installing stock intacke backplate
Re-installing original airbox on 09 ultra. Stupid me, forgot what goes on first. Assuming black plastic airbow first. Next two crankcase breather bolts. Airbox has an O ring on back, does the gasket go on front afitter airbox on, against the rear of the filter. Remember it falling off when I installed the SE plate, but forget where. Getting old I guess and memory is gone. Supprt bracket that went on first is a real SOB to get on, and I'll have t o do all again when I get the PCv sorted out. Anyone?
Think I have it figured out. What a setup, looks like an engineeers bad day in designing that setup. Put the airbox on and then screwed in the breather studs. Paper gasket went on before aircleaner ( had a time getting rubber tubes in holes in back of aircleaner then 3 screws in front mounting plate thru aircleaner and airbox to throttle body. Is this correct? I hope , at least I used all the parts at hand.
