Upgrading the upgrades
2006 FXST uped to 95" with SE10.25 to 1 pistons, SE211 cams, ported stock T/B, ported heads with 1.900" intake valve, stock headpipes and SE2 slipons. Turned 99HP at 5500 rpm and 97lbs. torque at 4900 rpm. Thinking of going with the SE257 cams and the 58mm T/B. What could I gain out of these changes, or should I leave well enough alone?
For that cam an increase in compression would be needed. Say 10.5 and the power curve on cam is going to be even more upper end than the 211. I have done a few of those kits way back when and you may see 105-108 hp , tq may come up some with the increase in compression but just a straight swap not much of gain, as far as money to increase goes.
http://www.zippersperformance.com/do...ist_030509.pdf They have the Fatcat here for $425.00 I see some real nice bikes on this site running these pipes and the price is right.
103-113": 103-113": 2015 FLSTN 110, Stock heads, SE 585 cam, GLS Ultimate Intake, Rinehart crossbacks
Yo_Boss
Dyno Charts
40
08-17-2017 07:19 PM
