Ping?!...
Ping?!...
'07 FLHRC... As long as I can remember, my bike made a very subtle pinging when I got on it a little. I figured it was some sort of pre-detonation or something... bike always ran great otherwize. Did the stage 1, and the subtle ping was still there... again barely perceptable if you didn't know the bike. Unusual sound though, so it was always in the back of my mind.
Well, on a roadtrip this weekend... couple of hours into the ride on a hot day and almost no gas in the tank (light was on), the pinging started at cruising speed on the highway (never did that before). It was pretty bad. I got off the road, gassed up, checked things out, and the bike went back to 'normal' only pinging when I get on it. Huh?! Figured it must be 'bad' gas and perhaps lending cred to my detonation theory. But WTF?! why is the bike doing this at all? It's tuned right on, I use good gas, maintain the bike way above HD standards, and I have 'pebbles' rattling around my engine?! apx 8K miles.
Any thoughts? I'll take the engine down if I have to, but never thought too much of the noise until it escallated on me in the middle of nowhere (didn't do much to inspire confidence in my relatively new bike). Advice/leads greatly appreciated. "Dunk"
had same thing on my superglide, got it downloaded...still there. put tts mastertune on it
played with using the maps...almost gone. then i started playing with autolite plugs
the ping was just about gone using one step colder#4163. last week i put in #4162
witch is 2 ranges colder and i havent heard any pings at all. but ive been fighting this
as far back as two years.... man this efi stuff is expensive!!! its fun though.
What about the built in spark retard.
Only way I can find my pinging is a forced method caused by my bad, time or two. Or when I, Record Data. Can see this on the graft.
Normally you should'n hear this and it shouldn't do it.
The tuner may have left the ,"spark retard" off which is a selectable in the SERT and the TTS, "engine constance" table. Check that out.
yea my knock sensor is enabled, i just havent had the time to do any data runs.
so i had some colder spark plugs laying around, gapped em and threwm in real fast, they
seemd to have cured my pinging. i know its pinging because every time i roll on the throttle
in 6th doing 70mph I get that pea gravel hitting the front fender sound.
very annoying.
very annoying.
