Need for Compression Release at Altitude
Quick question. I live in Michigan, where average altitude above sea level is 500-600. I had compression releases intalled when heads were done for my 95" build. My wife and I are planning a trip to Yellowstone/Bear Tooth/Tetons mid-June and wondering whether I'll need to use the compression releases? When I plug my specs into the Big Boyz calculator, the Cold Cranking Compression is much lower than my normal 194. Is there more to it than that? Thanks for any input/advice.
Ted
Ted
txphatboy
03-03-2013 12:41 AM
