Sponsored by: Jekill and Hyde
Spark Plugs
Old 04-21-2009, 07:38 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Default Spark Plugs
I asked this in the touring section but probly should have posted here first.
What plugs/part numbers would you motor guys reccomend for my build.
I'm running some old SE Platinum's right now.Dont know the numbers off hand.
95",Andrews 26G,SERT,Zipper A/C conversion,Propipe.
Dynoed at 95/98.
Thanks.
Old 04-21-2009, 07:48 AM
dawg's Avatar
dawg
dawg is offline
Received 3,227 Likes on 1,842 Posts
Honestly, I would run plain old simple Autolite 4164's. Cheaper than HD stockers. R&R runs those plugs in all their builds also.
Old 04-21-2009, 08:08 AM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
Second that
Old 04-21-2009, 06:54 PM
1flhtk4me's Avatar
1flhtk4me
Thanks guys.I give the Autolites a try.
Beats $15.98 plus 9 1/4 % tax for the SE's!
Old 04-21-2009, 10:35 PM
1711tab's Avatar
1711tab
1711tab is offline
Dynoed at 95/98.
Thanks.
I third that one... I use 4265 in my R&R CYCLE Raped Ape Billet Heads...
Old 04-22-2009, 09:31 PM
Dalton's Avatar
Dalton
Dalton is offline
Yep, Autolites work just fine...
Old 04-22-2009, 09:43 PM
TXCHOP's Avatar
TXCHOP
TXCHOP is offline
NGK fan here...I stock 2 boxes of stock and 1 step colder at all times..Must have installed a couple hundred with not a problem.
Old 04-22-2009, 10:28 PM
eddfive's Avatar
eddfive
eddfive is offline
I guess I have to respectivley disagree. A Twin cam motor shoud only use the Harley 6R12 plugs as this is what they were set up on. The reason I say this I have pulled many plugs out and replaced with the 6R12's as the Ion Sensing system is very sensitive to a current change. If you look at Spark Knock and the system it does not take much of a current/voltage change to throw the system off and it will pull timing and hurt performance. I have a full box of Harley Gold's, Platinums, Autolite, Champions etc.etc that I have pulled and when replaced with the 6R12's all is good and the Ion sensing system works just fine. Just to keep things on a level playing field I also have several 6R12's that showed a problem and when I replaced them with new 6R12's the Ion sensing system worked just fine. I am not saying the other plugs absolutely will not work I am saying why change from the stock 6R12's. This is one of the first test I run to make sure the plugs and Ion Sensing system are in sync. It really will hurt a tune if the Ion Sensing system is pulling timing because of a plug. I should also say I have seen plug wires and igntion coils cause similar problems. Make sure to check the data.
Old 04-22-2009, 10:47 PM
AR-15 DEUCE's Avatar
AR-15 DEUCE
AR-15 DEUCE is offline
https://www.hdforums.com/forum/touri...ug-to-use.html here are some plugs from a recent post..IMO stock is best
Old 04-23-2009, 06:10 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
NGK DCPR8E's. Period. On the hot-rods, there are gapped at .035".
Quick Reply: Spark Plugs
