Really fast idle...
04-19-2009, 12:41 PM
Really fast idle...
I have a 01 Harley Ultra with FI. I took it out yesterday and it started running a little high at idle (2000 rpm) When I got about 45 miles out it wouldn't idle below 3000 rpm. By the time I got it home it was idling at 4000 rpm. Any idea would be appreciated.
Red
04-19-2009, 05:20 PM
when my dyna did that the throttle stop screw in the throttle body had came loose and wouldnt let the blade close.
09-30-2009, 04:20 PM
I am having the same problem in my 2003 Road Glide. High Idling and engine light does not go out after engine starts.
10-01-2009, 03:47 PM
I have found that sometimes when I fire my bike up, it will idle up high, around 2000rpm or so. If I right the bike (stand up the bike), it will idle down.
10-02-2009, 10:09 AM
May very well be a leaking thru injector.
think about the simptons and what is happening.
10-02-2009, 10:12 AM
Could also be a bad fuel pressure regulator causing too much fuel to flow through the injectors
10-02-2009, 10:25 AM
check the TPS
kirby
vee twin racing
Jason Williams
07-30-2017 08:48 PM
scotsport
09-21-2013 03:43 PM
zz rocker
10-30-2010 04:13 PM
thehueg
08-15-2009 04:20 PM
Chief101
10-15-2006 03:41 PM
