New 95" kit with low power gain
But with your CCC and the cam specs and a few other numbers, you can plug them into a calculator like the one on Big Boyz website.........and it will give you your approx. CR.
Steve
good point. Do you know about any difference between the 88 cams and the 96 cams due to the crank stroke? I threw that in because I had heard that but it just seems like BS. They dont sell different cams for each and every SBC just because they have a different stroke (283/327/350 doesn't matter, all the same cam). Just asking because you seem to know what you are talking about.
To measure the deck height you will need a set of feeler gauges and a straight edge. You have to have the top end removed from the motor down to the cylinders with pistons in them. Bolt down the cylinders so they are tight to the cases and won't move around. Put each piston at it's highest point by turning the rear tire with the bike in 5th gear. When you find the highest point, lay your straight edge over the middle of the piston and use your feeler gauges to measure from the center of the piston to the straight edge if you are low. If you are high, measure from the straight edge to the top of the cylinder sleeve.
CC'ing the heads is something I leave to my head guy......Big Boyz Cycles. I know how it's done, but I've never done it myself. Maybe someone will chime in with their technique for doing it.
Steve
Steve
to cc the heads you need a Burette with cc measurements, take a some colored liquid (food coloring in rubbing alc works so does marvel mystry oil) take a flat piece of plex glass and drill a hole in the center, take some grease to make a seal and place the plexi glass over the head and turn the head upside down and fill thru the hole in the plexiglass make sure that it is completely full of the liquid and there are no air pockets and the amount of liquid used is the cc volume of the head. have the sparky installed.
Sage Counsel
Exhaust System Topics
07-22-2011 12:38 PM
