Redshift 575 cam w/PC-V in '08 103 Need map
I got an '08 103" Road King with stock heads(for now) Redshift 575-hs cams, Ness big sucker II a/c, supertrapp 2into1 exhaust, and Power Commander V from Fuelmoto. I'm looking for someone with the same cams and similar combo who might share their maps with me as Fuelmoto didn't have anything with same cams.
Do you have auto tune? Because if you do you can set the afr range to drive it. But here is the question what is the best afr and where to set it in the pc5. My 2 cents would be set it 13.5/13.8 for cruise mode then w/o/t at 12.5/12.8 afr. But you also have to watch your timing and where to set it. So bring it to someone that knows what they are doing.
haven't received PC yet nor have I installed any parts as I want to do all at once. didn't order autotune with it, but have had the thought in the back of my mind since I ordered PC-V that I should have ordered auto tune since Jamie pretty much just had SE-255 cam maps, and there's a HUGE difference in overlap between 575-hs and SE-255 cams.
