Which Cam? Help!
Which Cam? Help!
Hey all, I have an 06 Fatboy (fuel injected) and want a little more power. I currently have Samson pipes, stage 1 air cleaner, and HD ECM tune.
I would like to pick up a D&D Fat Cat 2 into 1, PCIII and I am wondering if I can put a bigger cam in stock 88" motor. Ive been doing a little research. What do you all suggest? 203 cam? 211 cam? Something else?
Thanks!
Thanks!
Without the cam you are probably right around 70-75hp and 75-80tq, after the cam install and a good dyno tune you would probably be around 75-80hp and 80-85tq.
Don't expect miracles with just a cam install. It will put the power where you want it and give you an increase..........but it won't blow you away.
Steve
Steve
here is a link to the zippers close out parts. i seen some good parts in here for real great prices. any one wanting a build should look at their pistons and cylinders.
pretty good pricing it just might be able to make a great build for a fraction of the cost
http://www.zippersperformance.com/do...ist_030509.pdf
G
G
