Looking for cam advice
I have a 2000 deuce, the engine is stock except for a mikuni 42 flat slide, screamin eagle intake manifold and air cleaner, and rush 2 inch slipons. The bike runs and sounds great and I get around 40-42 mpg. I got 26,000 miles and I'm getting ready to put it in the shop for the cam chain tensioners, bearings and all that. I want to have the cam changed also and have been looking at alot of cams & specs. Just looking for a bolt in with a little more in the middle as I do mostly highway riding, nothing crazy, gotta be my daily ride. I've narrowed it down to a SE or Andrews cam, but those numbers are confusing. My bike isn't really that heavy like a bagger so I know that makes a difference. Any advice for you guys that know how these cams perform wouls be awesome. Thanks a million!
The SE203 cams are good cams and can be had cheap if you keep your eyes open. The SE211 cams are for a little higher RPM range. Andrews TW26 cams are kind of like the SE203 cams as far as RPM range is considered. You might get a lot of opinions on this subject but that is my opinion. Later, Calvin.
the 21's are great in a stock 88". they wake the motor up and pull from low to ~4K rpm really well, and much better than stock above 4k. If you typically ride above 4k, then the 26's may be better. Lots of twisties, hills and country roads here so not a high rever, I love the feel of low to mid range tq so 21's fit my riding style. Just think about where you want the power band...
Received 24,095 Likes
Another +1 on the Head-Quarters 0034 Hurricane. Got a great torque boost right where it's needed, and felt. Made freeway merging fun again!
