LIL HELP WITH TAMK REMOVAL PLEASE
Old 04-24-2006 | 08:20 AM
geno3j's Avatar
geno3j
Default LIL HELP WITH TAMK REMOVAL PLEASE
Hi,
Trying to install new bars and want to remove tank, WTF I got the bolts off and lifted to see a mess, I disconnected the breather hose on front of tank and wnted to check how to do the rest. I will also change out the Rocker Box bolts once tank is off Hate the stock ones. Any hints on simplfying the remaoval of tank on a 05 Fat Boy with a Carb? Thanks
Old 04-24-2006 | 10:54 AM
PhilM's Avatar
PhilM
Default RE: LIL HELP WITH TAMK REMOVAL PLEASE
Remove the dash (gotta take the gas cap off & work the rubber gromet around the lip of the filler neck, disconnect the fuel line frrm the petcock, remove two (2) bolts at front of tank, remove one (1) bolt under the nose of the seat (rear of tank), pull of the vent tune from the filler neck, and I believe there is an electrical connector that drives the fuel guage to disconnect.
After that, it should pull off....
Old 04-25-2006 | 11:55 AM
geno3j's Avatar
geno3j
Thnaks Phil worked like you said. The sticky part where those dang OEM Fuel line clamps what a PITA
Old 04-25-2006 | 07:20 PM
DanDeuce's Avatar
DanDeuce
No cross-over hose on FB tanks ? Major messy pain in the @ss on my Deuce unless the tank is empty !
Dan
Old 04-25-2006 | 09:03 PM
geno3j's Avatar
geno3j
Yes there is a cros over and yes can be a PITA. Make sure you run her almost dry
Old 04-26-2006 | 12:40 PM
DeuceRider's Avatar
DeuceRider
Stage IV
What do you guys use in place of those factory fuel line clamps? I just replaced one with a hose clamp for now until I find something better.
Old 04-28-2006 | 08:59 AM
DanDeuce's Avatar
DanDeuce
I only took one side off and just used a regular clamp - screw type .
Dan
Tarkus60
12-08-2016 08:18 AM
silent bob
12-20-2012 09:36 AM
mrh1275
10-04-2012 08:24 AM
Cpitch
03-28-2011 01:25 PM
t059736
03-04-2010 09:00 AM
