Correcting Gear Drive lash
Greetings.
I'm currently working on a mild upgrade for an '01 TC88 Bagger. I've collected a pile of parts that are either slightly used or from abandoned projects including TW21G and TW26G cams and a set of gears (I'm leaning toward the TW21G partly for the smooth low end grunt, and partly because the 26G will sell easier)
In putting together the cam chest, the cam gears showed NO measurable lash in all four quadrants, and actually have an ever-so-slight drag in a 1-2 tooth section. When in the engine, they spin freely but will hesitate or stop at the aforementioned point. Fine, an undersized rear cam gear can take care of that if necessary.
Now I put the pinion gear on, only to find...NO measurable lash. No binding, but no lash. Ok, now we're up to 2 hundred bucks with the undersized pinion.
So I get to thinking, "It's gotta be the sloppy tolerances in the cam plate. Would another plate offer a difference ?". I could try the used cam plate lottery (ebay ?) and hope to get lucky with another one. And the cost of a Feuling plate isn't much more than the price of the 2 new gears (and I can do the Feuling pump that I was thinking about). Is this overkill for such a mild build ? So many choices...
If anyone has ideas, or preferences, I'd love to hear 'em. Or if you have undersized gears you're looking to part with, PM me.
Greetings.
Well, here's an interesting twist...
Before committing to shelling out a few hundred bucks for a new cam plate and improved oil pump, there seemed to be one more thing that could be checked. Since it's been fairly cold recently (20-25F) it seemed a good idea to warm everyting up a bit and recheck.
After an hour or so in front of the space heater, much to my surprise, suddenly there was a bit o' lash in the gears. About 0.0005 inches between the cam gears, and the same at the pinion gear. Apparently, the aluminum plate expanded enough from low 20s to 70F to create the necessary gear lash. So it seems my cam plate is OK after all, unless I ride in Siberian winter weather.
Thanks to everyone for their suggestions. I'm still going to consider either the Feuling, Delkron, R&R or Screamin Eagle Plate with an 07+ pump for extra bottom end insurance.
