idle stalling
RE: idle stalling
Mine did the same thing. Dealer said to let it warm up a good 1 to 2 minutes when cold. Also blamed it on the reformulated gas that changed over on April 15th. And lastly don't blip the throttle when coming to those stop signs when engine is cold. I was doubtful but it worked for me. Still seems like it wants to stall but it seems to work.
RE: idle stalling
If you have to go through the routine of waiting for the bike to warn up why have FI instead of a Carb. The advantage to FI is that you are not suppose to wait. Sounds like you have the injector issue. Ask for the 25 degree and get the 8 degree replaced. $20K plus and you have this BS
RE: idle stalling
I know this is going to sound really stupid, but desktop diagnosis' really are as useful as tittz on a Bull....
Are you letting the CEL turn-off before you start the bike?
Is the Fuel Pump whine stopping as the CEL turns off?
Is the bike starting at a high idle (1200 rpm), and then dropping down to 1000 Rpm?
Are you "Blipping" the throttle?
What is the part # on your injectors (Get a flashlight and post all the #'s that you see on them (Both of them).
Are there ANY mods done to the bike at all?
RE: idle stalling
Bob,
does not sound stupid, I am on the same page but running out of options.
The bike does start at a high idle and then drop down exactly as you described, on the nose what does that mean?
As far as I know I always wait for the CEL to turn off.
Not sure about fuel pump wine, but I have not noticed it.
I may be blipping the throttle, I tend to do that.
I am aware of the injectors and will check ASAP, bike at local HD dealer for this and other issues.
I appreciate any advise you may offer.
Randy
Randy
