SE A/C compatabilty
SE A/C compatabilty
I been looking for a stage 1 SE ac set up(e-bay) for my 05 dwg, are all these interchangeable or do I need the specific # to get it to run right .For instance will 1 work that is off a 06 road king,as long as it is a twin cam ??I have been looking for a month or so and its a pita to try and find # specific.Thanks for the info and have a good one
Here's the whole scoop from the Screamin Eagle Catalog (On-Line). I believe you would be looking for the 29773-02C, but the whole tamale is copied below:
A. SCREAMIN EAGLEŽ STAGE I
AIR CLEANER KIT TWIN CAM MODELS*
Kit features a one-piece cast back plate with integral
breather and mounting brackets for simplified installation,
and a state of the art synthetic media washable air
cleaner element that does not require oiling. If you want
more torque from your Twin Cam-equipped model, this kit
provides a freer breathing capability to pump-up the power
of your EFI-equipped motorcycle. This kit includes air cleaner,
breather, and all required hardware. Street legal when used
with stock mufflers. All EFI-equipped models require ECM
calibration* (priced separately).
*Recalibration is required for proper installation, and will
allow engine to rev to 6200 RPM. See dealer for details.
Labor cost not included.
29773-02C $139.95
Fits 01-07 EFI Softail, 02-07 EFI Touring, 04-07 EFI
Dyna and models equipped with Accessory Air Cleaner
Covers. (Stock on 05 FLSTFI 15th Anniversary, 05-07
CVO Softails, 07 CVO Dyna, and 07 CVO Road King
models.) 06-07 CVO Electra Glide models require the
separate purchase of Air Cleaner Cover P/N 29121-07.
Air Cleaner Trim is sold separately.* (shown)
29406-08 $149.95
Fits 08-later Dyna models with Original Equipment
Air Cleaner Cover.*
29440-99D $139.95
Fits 08-later Softail, 08-later Dyna equipped with
accessory Air Cleaner Covers (stock on 08 CVO Dyna).*
29260-08 $139.95
Fits 08-later Touring models with Original Equipment
50mm Throttle Body. 08-later CVO models require
separate purchase of Air Cleaner Cover P/N 29121-07.*
29489-99C $139.95
Fits 99-01 fuel-injected Touring models.*
_____________________________________________Fits 01-07 EFI Softail, 02-07 EFI Touring, 04-07 EFI
29406-08 $149.95
Air Cleaner Cover.*
29440-99D $139.95
29260-08 $139.95
29489-99C $139.95
B. SCREAMIN EAGLE PRO AIR CLEANER AND
BREATHER KIT TWIN CAM MODELS
The die-cast back plate and high-flow, washable air filter
provide large volumes of clean, stable air to the engine. The
crankcase breather system utilizes individual breather hoses
that direct the breather gases into the mouth of the carburetor,
or EFI induction module, to minimize excess oil in the
system. Kit includes all required hardware and installation
instructions. All EFI-equipped models require ECM calibration*
(priced separately). For race application only.
29440-99D $139.95
Fits 00-later SoftailŽ, 99-07 Touring (except 99-01 EFI
models), and 99-07 DynaŽ models. Also fits 08-later Dyna
models equipped with accessory air cleaner covers. Fits
EFI models and carbureted models with original equipment
CV, Screamin Eagle CV (except CV51mm Super Bore), and
Flatslide carburetors. Also fits 06-09 CVO Electra Glide,
09 CVO Road King, 09 CVO Road Glide, 08-09 CVO
Springer and 09 CVO Dyna models with separate purchase
of Air Cleaner Cover P/N 29121-07 or accessory air cleaner
cover. Stock on 05 15th Anniversary FLSTF, 05-07 CVO
Softail, 07-08 CVO Dyna, and 07 CVO Road KingŽ models.
29441-99A $139.95
Fits 99-01 EFI Touring models. (not shown)
29440-99D $139.95
29441-99A $139.95
I would like to change the tear drop air cleaner cover and filter on my new 2009 Fat Bob to a round one. Can I use the p/n 29586-06 round backing plate and k & n 0800 a/f as replacement? I already have a nostaglic bar & shield round air cleaner cover p/n 29138-91 I want to use. Help please.
bbqbrisket
12-03-2011 02:03 PM
sweetglide06
Touring Parts
06-24-2010 02:59 PM
drspencer
Exhaust System Topics
06-13-2010 12:03 AM
