95 inch build pinging, looking for fix
My 95 build has a pinging problem in my cruise range (2800 to 3200 RPM). I found out that my S&S 510 cam is speced for 9.7 to 1 or less, and I am at 10.5 to 1. It was suggested that I go with a 570 cam to fix this. I am wondering if I could achieve the same 100/100 results by going to flat top pistons and getting the CR down to 9.7 to 1. I'm concerned about starter problems if I go with the 570 cam. I haven't had any starter issues with my current set up, but I am concerned that if I get the correct cam for my CR, that I will develope starter issues. If I went to flat top pistons, what gaskets would I need to get 9.7 to 1 CR? What would be easier, changing the cam, or changing the pistons? What would be more cost effective? Which would give better, more reliable results? I am more interested in torque than big numbers on HP.
'04 RoadGlide
2 up 70% of the time
SE performance heads (not HTCC)
compression releases
SE HC 1550 pistons
S&S 510g
feuling oil pump
stage 1 A/C
PCIIIusb
White Brothers E series pipe
[IMG]local://upfiles/8977/AE81B0032A864CECA6A30A6B274C3535.jpg[/IMG]
'04 RoadGlide
SE HC 1550 pistons
S&S 510g
feuling oil pump
stage 1 A/C
PCIIIusb
