Comments on 96 to 103 build results
Old 02-12-2009 | 09:43 AM
bigdoghd's Avatar
bigdoghd
Originally Posted by mgmmgm
Anyone want to chime in as to their " after" build experiences - that their bike runs better in such and such a way, better this or that etc.
Also, will the stock MoCo throttle body work that well, going to a 103 build ( gotta check Zippers Performance to see specs on 575 cams- I have and will use for the 103 build, and or do others change up to a bigger t-body; my compression will be 10:1.
Thanks again all. Mark
Mark we just did a upgrade to my 2007 bagger (103) I bought the Screaming Eagle intake and found that my stock manifold flowed better on the flow bench with my combination than the SE, so I returned it. Nice to have equipment to confirm during a build
Old 02-12-2009 | 10:32 AM
lkr0's Avatar
lkr0
I am going to have a slightly used AIM VP84T for sale--I used it for less than 100 miles. I'm selling for $150 to include shipping. My HQs 107 is putting out so much Torque I am upgrading to the 92t--if interested let me know via PMl(Parts#VP014-84T) Fits '98 and later Big Twin model's stock clutch Engine size up to 103"(1690cc) Stroker motor. 20% reduce clutch lever effort Up to 103" motor with stock spring. Up to 124" motor with Screamin Eagle heavy duty spring.
Hi
Yeah, I checked out the AIM clutch set up. I e-mailed my Indy and he was checking it out too. Think that's going to be the plan. Will be nice to save my arm and not slip or fry my clutch out.
Old 02-12-2009 | 07:09 PM
cowboy1's Avatar
cowboy1
Default Done
Finished the build today and it runs sweet. Every gear pulls like 2nd gear. I didn't push it on the test ride cuz I just wanted to get a few heat cycles through it. I'm gonna get a couple hundred miles on it then put it on the dyno. I ended up going with a SERT rather than staying with the Ness Big Shot...anyone wanna buy a ness big shot tuner?
SE 103"
Mild port
Springs
SE 260 Cams
Old 02-13-2009 | 01:47 AM
wrenchturner100+'s Avatar
wrenchturner100+
Stage I
Default 103"= great power
i work at a local shop in north idaho. We do all machine work in house and ive done about 10 96"to103" along with s&s 510 or 570g cams, while basley heads are great we also do custom ported heads using .090" bigger int. and .040" ex. with a flowed seat on both (valve seat concentricty under.0008" see what basley puts out) not to knock his heads but we put out a product about 95% as good for 50% the cost. the only diff is we do not use a flow bench (whitch is only needed in race apps) to make a long story short the last 96"to103" we got 108hp 111tq at the wheel, using ft pistons, not to shab also used the SE58mm throttle body. im in the process of building another one with the same cams and a 50mm body im thinking that i can gain intake veloicty with the 50mm as opposed to the 58mm we will see sone ill put up a post with the fianal numbers.
jeff
Old 02-23-2009 | 10:36 PM
Lance03's Avatar
Lance03
Default 103" build
jeff
Hey Jeff,
If your in Coeur d' alene, I think that new build that you are doing is mine. I ordered a new set of billet clamps from Thunder max for the 50mm t/b, you should have them by Wednesday. Hopfully Lucky will have my heads done by then. Looking forword putting some miles on it soon.
Hoytman1968
Engine Mechanical Topics
05-29-2016 07:21 AM
fastbagger
09-17-2012 09:04 AM
Sadthorn
18
01-22-2011 08:15 AM
MoChrome
08-30-2010 02:43 PM
kart11
11-25-2007 12:49 PM
Quick Reply: Comments on 96 to 103 build results
