Sponsored by: Jekill and Hyde
Opinions wanted on 103 build
Old 01-25-2009, 01:06 PM
FXSTDSE2's Avatar
FXSTDSE2
FXSTDSE2 is offline
Good luck with that! The best I have pulled off with my 9:1 ultra is 104 lbtq with a woods 6H w/4* adv. gear. Thats with a CVO 103 head with 1.94 intake valve. The MVA heads have huge ports and valves so I couldn't imagine the combination pulling any good low end torque. But it will fly once you get it wound up!! To pull off 115 lbtq you are going to need at least 9.8:1 compression and a street ported head and the right cam.
Old 01-25-2009, 01:39 PM
chad peterson's Avatar
chad peterson
chad peterson is offline
Not gonna happen! Plenty of advice & info on this already, gotta wait! All I gotta say!
Old 01-25-2009, 03:22 PM
Rebel78's Avatar
Rebel78
Rebel78 is offline
If 9:1 ratio won't get you the numbers you want, then go for a higher compression piston, but dont exceed 10:1 if you wanna maintain reliability.
Old 01-25-2009, 04:58 PM
SEDELUXE's Avatar
SEDELUXE
SEDELUXE is offline
Originally Posted by Sandmankc
I guess I should have asked this a little differently. I fully understand the difference between SE parts and having my heads reworked. What I am looking to know is if anyone has had success building a 103 with good heads and cams and got around 105 HP and 115 ft-lbs of torque at 9:1 compression. It makes no difference on the SE vs HQ parts my dealer wants to put in 9:1 pistons and says they can get the performance I want. I haven't read anyone getting these results at 9:1 compression.
9.8-10 - 0 copression
yes it can be done
baisley heads and tw6 cam.
Old 01-25-2009, 06:10 PM
beaureed445's Avatar
beaureed445
beaureed445 is offline
I totally disagree with the statement above. There are MANY people on this forum running more than 10:1 compression, AND have reliability. Don't get me wrong, Rebel78, we don't live/ride in 130* heat (like you), but you can definitely run over 10:1 and have reliability. Just my .02
Old 01-25-2009, 06:56 PM
chad peterson
Agreed completely!
Old 01-25-2009, 08:37 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Running 10.5 pistons with MVA heads ,58mm TB , have plenty of low end torque . Don't believe all the naysayers that say big valves kill torque ,big TB's kill torque , they don't if set up with all the parts thought out ahead of time not hodgepodged together.
Old 01-25-2009, 09:24 PM
SEDELUXE's Avatar
SEDELUXE
SEDELUXE is offline
i ride the snot out of my build in my sig... i do not worry about reliabilty at all..if the parts compliment each other , installed correctly and the TUNE is correct reliabity should not be an issue
Old 01-26-2009, 12:01 AM
hpfatboy's Avatar
hpfatboy
hpfatboy is offline
Originally Posted by chad peterson
Agreed completely!
2nd THAT, Im at 10-2-1 comp. no issues at all. Runs like a swiss clock.
Old 01-26-2009, 02:00 PM
Kingofcubes's Avatar
Kingofcubes
Kingofcubes is offline
Default compression
I run 10.8 to 11.2 to 1 all the time on pump gas w/o pinging. Pinging is a result of heat and pressure, take the heat away with VE and you can up the pressure. Ask Tim Brindley in Arizona, he's running a 131" Hypermotor at 11.6 to 1 on 87 octane and has 156 horse. I would be sceptical of those numbers at 9:1 except for one cylinder head out there at that cubic inch.
Tripleshot
01-24-2014 01:07 AM
FLYER
12-21-2013 03:51 PM
TRUSTNOBODY
07-09-2012 08:05 PM
Base401
12-04-2008 11:10 PM
Hammer02
02-26-2007 11:21 PM
Quick Reply: Opinions wanted on 103 build
