yes they will work. But you will still have a 88" motor. What gives the 96" motors the extra inches is the stroke. But The juggs and pistons are the same.
The jugs are the same but the pistons are not. A 4" stroke (88) piston has a different wrist pin location compared to a 4 3/8" stroke (96) piston. If you used a 88" piston on a 96" engine it would hit the heads and not let the engine turn over.
Thanks guys...my fatboy is starting to rattle, time to put a tighter set of jugs and pistons in, thought I had just e-bay some re-bored cylinders and go with flattop SE cast pistons.
