want new pipes
want new pipes
I got my new FXD on monday,And i want to put different pipes on it,but i'm not sure which i want.A 2 into 1 like the thunder header,Or the V&H short shot staggered.If i spend money for pipes,I want an increase in power or torque.But i want it in the lower rpm range.I want it to sound good but more importantly if i spend several hundred dollars for pipes,they better do more than 'sound good' Does a 2 cylinder bike respond better for torque increases with a 2 into 1 pipe or 2 seperate short pipes?
I picked up a used set of V&H short shots for my superglide today! the guy wanted 125.00 but i got them for 100,Theres a few minor scratches that you cant see when the pipes are on the bike,And one of the o2 sensors is stuck in the bung,He tried to get it out but rounded it off and ended up cutting the wires to it.So i got home took the pipes to the shop and put a little heat on the bung and the sensor came right out and the scratches i worked over with some very fine steel wool and brick dust,theres only 3 deep scratches in the chrome but you wont see them anyway.And i also picked up a better seat,it's a little narrower and puts me a little closer to the pegs.(i'm only 5'7)and that cost me 100 also,the guy only used the stuff for last summer
Im thinking now that i should have gone with a 2 into 1 pipe,i looked at the V&H pro pipe,and a couple of others.if i understand it correctly a 2 into 1 appears to make a smoother more equal flow of exhaust of the engine,and places the torque at lower rpms' which is where i want it,and a short shot put any power gains at the upper rpm's,and i'm not likely to run at 4500-5000 rpm constantly to enjoy my power gains.I think i can still get my $100 back for my short shots,a buddy of mine says he would have bought them had he seen them first.But yikes on the 2 into 1 pipes! they are not cheap!
