88inch upgrade to 95 inch any advice ?
I have a 2005 roadking with power commander ; big air sucker ; true duals w/rhinehart eagle beaks. After many thoughts I'm planning to go with the andrews gear drive TW50 cams w/ new 95inch cylinder/piston upgrade. Also have the heads reworked . Any suggustions or thoughts?
TW50 might deliver power higher than you'd like. On a heavier bike I'd look at something that works well low-midrange. The TW50 is more of a higher rpm cam for light bikes. You may want to decide where you'll be compression wise before choosing a cam.
Your "head guy" should be able to make recommendations based on riding style,etc. I am by no means an expert.
More Wrong Info
Zippy,
Again, your "mechanic" is not up to speed with what the hell is happening.
A 95-98" bore, on your seasoned cylinders, along with an Andrews 37,(or a 26 if low/mid is in need) or what we would prefer, a Wood 6, set at 10:1, along with the proper cylinder head modifications, and then tuned correctly, will have you KNOWING, that it was what you were looking for. Absolutely no doubt about that, whatsoever.(even more on tap with larger cam/compression)
Very broad power from just up off idle, to 5500 plus.
Very smooth, and increased fuel economy as well.
Do not even have a clue as to how many of these combinations we have done.
No BS, all truth.
Scott
No BS, all truth.
Scott
