K&N "OEM' Filter as replacement for OEM?
I have an '07 Fatboy with V&H Short Shot Staggered pipes and I have been wanting to change over to the K&N HD-1499 OEM filter which K&N tells me I can and the o2 sensors will adjust for it without remapping. Is this the case since I am only changing the filter and not the actual breather casing with the original opening?
If you just change the air filter element, from stock to the K&N version, it will not measurably alter your air/fuel ratio. It also will not measurably improve your performance. You will not have to do any remapping.
If you change the complete air intake, from the, stock setup to a stage 1 version, such as a SE air filter system or equivalent, this will alter you air/fuel ratio and you will have to do do a remap.
Tom
Tom
adjustment, air, amsoil, davidson, equivalent, filter, fuel, harley, hd1499, installing, kn, map, remap, replacement, stock
