to all the x-perts do you guys have a special tool to remove cams from cam plate dealer wants 240.00 for that bad boy pt no hd 43644 i own small shop in ohio can get a jims tool through DRAG but still salty priced just wondering if you guys had any tricks.
thanks Jeff in ohio
pull the clean out plug out of the cam plate and put the whole assembly in the oven for about 20 minutes on 400 and the cams and bearings will come right out. You can also use the freezer and the oven to reinstall new bearings and cams into the plate.
Too funny. Thats the info I pm'ed him with. I was afraid to post and get flamed...
