which cam
Old 12-19-2008 | 06:12 PM
slack20's Avatar
slack20
Default which cam
stock 88 pc111 installed arlen ness big sucker also have rhinehart 2-1
andrews 37
h.q 0034
woods tw-6
might mention this is on a bagger thinking also of doing some mild head porting
thanks in ohio
Old 12-19-2008 | 06:35 PM
mtairy biker's Avatar
mtairy biker
I vote for the andrews 37
Old 12-19-2008 | 07:33 PM
splitting_lanes's Avatar
splitting_lanes
Andrews 26
Old 12-19-2008 | 10:18 PM
wrenchguy24's Avatar
wrenchguy24
so so so many choices !!!!!!!
Im doing a big bore and cams this winter also!!!!!! The more reading I do the more I get confused!!!!!!!!!!!!
Old 12-19-2008 | 10:36 PM
zoomie67's Avatar
zoomie67
Your gonna have to provide a little more info about your mods. It sounds like you are looking for a cam that will work with the stock configuration. If so you can run an Andrews 26 or 37 with good results. The HQ 0034 is reported to be a good one as well. If you are looking to do other mods I would suggest just saving your money and doing the build all at one time, it'll be cheaper in the long run.
Old 12-19-2008 | 10:43 PM
NTrat's Avatar
NTrat
Bagger+ light head/valvework ='s Andrews 26 cam.............a no nonsense low end torque cam. Wont be a dyno champ, but it will put the power where its needed for you. =D
Old 12-20-2008 | 12:33 AM
H&DCYCLES's Avatar
H&DCYCLES
thier are so many variables to this, are you planning on doing the work your self?
Old 12-20-2008 | 04:45 AM
hpfatboy's Avatar
hpfatboy
Thumbs up
Bobby woods tw-6g all the way!!!!!!!! Torque, torque , torque and more torque. Worked great in my 88, now works even better in my 95. This cam loves the higher compression , running 10-2-1 now. But it still ran fine in the 88 , with stock compression. Its your call , many different opinions and ideas here.
Old 12-20-2008 | 08:20 AM
slack20's Avatar
slack20
Default cams
yes planning on doing the work my self except the heads
THANKS MEN
Old 12-20-2008 | 07:20 PM
slack20's Avatar
slack20
Default cam
hey Nrat why the andrews 26 over the 37 because of the heavier bagger or the low end please explain.
thanks in ohio
Quick Reply: which cam
