SE 251 and 253 cam info needed
Old 09-18-2011 | 01:34 PM
fxdxrider's Avatar
fxdxrider
I think the compression/cam lift correlation is not as important as the compression/cam duration one. Basically the longer duration cams (and usually a corresponding overlap increase) moves the power up the scale and you might get some lower end power loss. Increasing compression has the effect of putting some or all of that lower end power back in. Higher lift cams will give a boost to the low-mid power but often require a bit more duration if the profile isn't going to be too tough on the valve train. Someone who actually understands this properly like "djl" would probably be able to explain it better.
Old 09-19-2011 | 09:11 PM
Papamte's Avatar
Papamte
You'll do better if the compression is at least 10:1 for the 251's. That is what my bike has, and it works out quite well.
Old 09-19-2011 | 10:16 PM
Blk and Chrome's Avatar
Blk and Chrome
Originally Posted by ian d
this summer i went with 103" jugs and had S&S do the heads. se 253 cams with hugh comp. pistons and increased the combustion chamber. dont let anyone fool you the cams are fine. im getting 95 hp and 105 ft/lbs of tq.. bike is fastest from 30 to who knows cause it burries the needle in the blink of an eye. im not pullin bags so there is a weight difference.
I'm at almost the same numbers as you are with 204's. Almost the same combo as you, 103" and the heads have a street port done on them set the deck at .004 and a 0.30 headgasket
Old 09-20-2011 | 09:39 AM
rambobob's Avatar
rambobob
I like mine. If your running any hiils loaded up not the best. It will scream with just you on it. Two up runs good but have to shift down when getting on it.
moose545
02-02-2018 06:50 AM
Mechanic77
09-21-2010 07:22 PM
harleycharlie1992
02-25-2010 06:15 PM
marinepilot81
16
11-14-2008 10:53 AM
DCRANER
05-09-2006 01:59 PM
