Looking to build an 88 on Road King to a 103 or 107 and need advise!
I am looking for advise on building my 88" Road King to a 103 or 107. And who you would use to go with the build.
To start with, I was thinking about building a 95 or 98 engine. But, after looking around I do not want to spend 650 to weld and balance my stock crank. So I am thinking about buying a SE 4 3/8 crank and have it welded and balanced or just buying a S&S crank if I can just drop it in.
Then I am trying to decide to go with HQ, Hillside or Bishops for the build parts.
I am leaning toward Bishop's because of the fact they gave me a great price on the parts including the bearing conversion and balance/weld the crank. Also, they are only about four hours away and can have them dyno the bike after the build. But they are against the 98 build due to cylinder thickness.
Hillside and HQ gave me about the same price on a 98 build but did not include the machining work or crank. That would have to be done at Darkhorse. I am looking at spending about 1400.00 for a new crank, 650.00 to balance/weld a new SE crank and 400.00 for bearing conversion.
Please let me know if you have any advise on doing this build and if you have used any of these builders. Also, if you know were I could have the dyno work done with in four hours or so from Columbus, Ohio....Thanks
Please let me know when going from an 88 inch engine to a bigger build, lets say 103 inch and up. Has anyone experienced more vibration in the handlebars or footboards while ridding around town or on the interstate then they did on there stock engine? I know that would drive me crazy on a trip and would stay with a smaller build if that was the case.
