Sponsored by: Jekill and Hyde
New Build/Your Thoughts?
Old 12-13-2008, 01:47 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
Default New Build/Your Thoughts?
Can I get a some opinions on a (98") build I'm considering? I'm thinking on upping the compression to 10:5 with Kury TC26G cams, Wiseco forged flat tops, HPI 48mm TB and appropriate head work (valves-1.9I/1.62E) Good, bad, ugly? What would you do different and why?
Below is my current build
05 Eglide
98"
37g's @9.7
mild street port heads (Kibble White valves/stock size )
Timken conversion
Darkhorse Proplugged crank/no weld
stock throttle body
D&D Fatcat
VPC clutch
Thundermax AT
Thanks,
Rick
Old 12-13-2008, 01:58 PM
Kingofcubes's Avatar
Kingofcubes
Kingofcubes is offline
Default Options
Domed pistons to achieve 10.5 to 1
HPI 51mm, more torque and horse
RR525 cam quick torque and less oil temperature @10.2 to 1
If you going to use that 26 cam consider a set of 1.72 exhaust rockers to get more heat out.
Old 12-13-2008, 02:50 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
Randy,
Thanks for the input, I have a couple of questions.
How much do you think the 48mm TB will limit me? I got it cheap and a new one will be a budget buster.
Why the domed pistons? Won't the flat tops get me to 10:5? I have a set of low mileage Wisecos I was hoping to use.
What brand rockers do you recommend?
Thanks,
Rick
Old 12-15-2008, 08:41 AM
Egldr05's Avatar
Egldr05
Egldr05 is offline
Any other opinions?
Thanks,
Rick
Old 12-15-2008, 05:27 PM
Kingofcubes
Originally Posted by Egldr05
Randy,
Thanks,
Rick
48mm compaired to HPI 6-9 torque and horse.
I would rather use domed pistons than wack the heads for future mods and the intake will not have to be refit.
R&R makes the best rockers and they will split ratios.
Old 12-15-2008, 05:33 PM
Kingofcubes
Any other opinions?
Thanks,
Rick
Stage 2 cnc porting to remove core shift and balance velocity and cfm's front to rear.
Without hacking the heads down you will need an 8 cc dome for 10.3 to 1 compression at 98"'s.
Old 12-15-2008, 06:33 PM
SEDELUXE's Avatar
SEDELUXE
SEDELUXE is offline
"The best is an oxymoron" isnt that what you said to me Randy on another site when comparing heads.... R&R makes some good stuff but they falll right in line with every one else.
Old 12-15-2008, 07:05 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
The 48mm is an HPI, I picked it up used at a good price. I thought the 55mm was more for the 107+ motors.
Sounds like I should try to fit some new pistons in the budget.
Thanks,
Rick
Old 12-15-2008, 07:34 PM
Kingofcubes
Talking George
It's an oxymoron when it comes to heads on that other forum! I have seen issues with "every" manufactured roller rocker except the R&R's (knock on wood).
All The Best
Old 12-16-2008, 09:57 AM
SEDELUXE's Avatar
SEDELUXE
SEDELUXE is offline
Randy good cover up.. the reason i think yopu do not see any issues with R&R products is that they handle any problems immediately. there forth it never hits mainstream. i highly doubt they are a trouble free company they just handle it diffrently which is excellant
Quick Reply: New Build/Your Thoughts?
