Jims 4 5/8" crank Salvageable ?
Hey guys , bought a used Jims 4 5/8" crank from a shop , i was told it was in good shape , got the crank in from UPS and to my surprise wasn't in the shape that was described to me over the phone . Imagine that ...
Theres some scoreing on both the pinion and sprocket shaft and some grooves on the end of the pinion shaft . Haven't had a chance to check the run out yet , the only way that i could do that is take it to my buddies shop and chuck it up in his lathe and check the run out that way .
If you guys could take a look at the pics and let me know if this crank can be saved let me know .
UPDATE 12/14/08
went and measured the runout yesterday at my buddies shop :
flywheels where both .014
end of the pinion shaft .007
end of the sprocket shaft .004
Brent
UPDATE 12/14/08
Brent
