Does 95" - Flat Top Piston Make Matter?
There are thousands of post on 95 inch BB upgrades. Most discuss compression and cams.
Does any one have any quality suggestions on a flat top? Cast / Forged / Hyper or Regular Alum.
It may all depend on the build, but here is what I will be working with:
HQ 0034 cam
V&H Pro Pipe 2into1
Indy bored OE cylinders
AN Big Sucker
TMAX w/A-Tuner
Around 10:1 compression
Cleaned up OE Heads
Is there a major difference between SE / Keith Black / Wiseco when it comes to moderate compression on a 95 upgrade?
HQ 0034 cam
V&H Pro Pipe 2into1
AN Big Sucker
TMAX w/A-Tuner
Cleaned up OE Heads
Keener let me give you some advice from experience, I went with alsost the same combo your going with and I used KB's, if you use them you piston to bore clearence is very critical (very), say no more than 1 1/2 thous, the SE cast flatops are excellent pistons and are user freindly, if I had it to do over that's the ones I would use or go with there 10.1 cast, it will be fine for what your doing and will save some cash.
Decided to use those 0034's huh, I think you'll be happy.
