Cam Chain Adjusters
Andrews mentions "port cover" below, appears this is actually blocking the port that feeds the adjusters.
From Andrew's TC 96 Gear Drive instructions:
7. Both stock hydraulic chain adjuster assemblies can
now be removed. Be careful not to lose the pistons and
internal springs which are part of the original chain
tensioning and oiling system.
8. Oil port covers can be installed over both orginal chain
oil ports since the gear drives do not use chain lubricators.
Reading the rest of the instructions finds no other mention of the adjusters.
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
Hey Ron,
No need to go to the gear drive in the 07 and up. It appears that HD has solved the tensioner problem with the new design. You can save yourself some bucks. I am running the stock tensioners in mine and so far it is fine at 30k miles. A few others may chime in to verify what I am saying.
http://www.andrewsproducts.com/motor...nstall_Kit.htm
If you're seriously considering the conversion, get in touch with John (Herko-Bagger) here:
http://www.flyingwperformance.com/
He offers the conversion kit, and is great to deal with. Excellent customer service!
HTHs!
