2005 Superglide oil leak
Old 11-17-2008 | 12:12 AM
indiebarjohn's Avatar
indiebarjohn
Default 2005 Superglide oil leak
My 05 Super has developed an oil leak near the bottom rear of the engine. Drops about a tablespoon when I stopped. Only 12,000 miles on the clock. Do you think this will be expensive?
Old 11-17-2008 | 10:42 AM
new_mentor70's Avatar
new_mentor70
you will have to varify exactly where its comming from first.
if its the cases, Yes it will be expensive, hopefully it is just and oil presure sending unit or cam cover gasket which is not a big deal.
Old 11-17-2008 | 10:46 AM
meepers's Avatar
meepers
May also be leaking from one of the oil fittings on the right side of the engine, and pooling at the trans mount. Get some simple green in a spray bottle, and a soft bristled scrub brush, Clean the area really well, rinse with water and dry. Start the bike and let it idle, with it clean, it should be fairly easy to see where the leak is coming from.
Is it a blond motor or black?
Old 11-25-2008 | 07:40 PM
Keener's Avatar
Keener
I replaced that shaft seal awile ago. Had to replace a bum stator, thought I would fix my leaks as well. The seal I go at the dealership looked like a 3 cent o-ring, glued to the bushing. I figured, what the hell and installed it anyway. Here is an incredible HD post showing directions, and a quality looking seal. My $.03 seal is already leaking again. Get teh Cometic if you have a bad seal.
Read this instructional post. One of the best ones I have seen. https://www.hdforums.com/forum/touring-models/89699-got-an-electrical-problem-need-help.html
Old 11-25-2008 | 08:55 PM
Gadgetech's Avatar
Gadgetech
Gonna have to watch this one. I have an 05 LR with 10k and the same problem. I want to blame it on the Redline Shockproof that I changed back to M1 since that is a common myth.
Old 11-26-2008 | 01:03 PM
new_mentor70
I has Shock proof in my trans too, the seal on the trans output took a dump within days!!!
but I think I over filled it. Still had warrenty at the time, and had them fix it.
bparsel
EVO
27
05-06-2021 07:01 AM
Hannibal Smith
Shovelhead
43
11-14-2018 12:20 AM
joewg3
01-05-2015 08:16 AM
havoc1354
12-03-2012 09:40 AM
ninetyfivebravo
09-10-2008 10:35 AM
