Fuel Gauge Problems
RE: Fuel Gauge Problems
phtby,
I have an 01' FLHTC carbed and I just replaced my fuel sending unit last week. I checked with the stealer and they asked if I filled my tank all the way up and I told them I did. Their response was that because I filled the tank to the top that the float got bent. I knew at this point that I was talking to the wrong person. If what they said was the truth it would register full not EMPTY! I ordered the part and I thing it was about $67. Installed it myself. I did have to change the wiring connector on the bike to fit new connector on fuel sending unit. Problem is now fixed and the fuel level now seems to be more accurate than when it was new. Every since it was new the "low fuel" light would come on at about 1/2 tank.
When I took out the old sending unit, I looked at it very closely. What appeared to be the problem is that float rod rides on a electrical contacts on a circuit board in on the unit. The rod connecting point is very sloppy due to wear and was not making contact. Turned the unit on over and it is stamped "MADE IN JAPAN"! Nough said.
Mine is not on empty but it is inaccurate in the other direction.....last night I was throwing some wax on the tanks and discovered that the fuel gage had popped up out of the tank! I shoved it back in .....hope I don't have trouble with it.....I am so use to paying no attention to it. Tripometer.
Thanks for the information. I laughed when I read about your experience with the dealership as that is why I don't want to go to the dealership first. I think it may be the wiring, as it happened after I washed the bike. Where is the wiring for the sending unit located? Your help would be much appreciated.
