HP Limitations ?
HP Limitations ?
Trying to come up with a build for my 07 softail. If possible I'd like to rework my stock crank and keep the stock tb. Looking for good low- mid range torque and power as the rev limit will be set to 5600-5800 anyway. My main concern is the narrow drive belt not holding up. The plan is for 113-117 ci, but thoughts and suggestions from experienced engine builders on these matters would be good. At what point would the injectors need changing to accommodate larger builds?
Ron
Ron
Thats a maybe on the injectors depending on the build
The drive belt is also a maybe depending on how you ride. I beat the **** out of my 117 and now my belt is stretched beyond adjustment.
Yes the stock crank can be revamped by darkhorse.
the stock throttle body can be used as well, but always best to match all parts of a build combination.
Here is a website that may help with the injector size problem http://injector.com/injectorselection.php. Scroll to the bottom and use the "Fuel Injector Max Capacity Worksheet". The HD injectors are measured in grams per second. You will need to convert this to lbs per hour. It seems like that the 3.91 gs/sec = 31 lbs --- 4.35 = 34.5 lbs --- 4.89 = 38.8
It's probably less that you would think.
Our EFI tuner generally uses the HP Inc "yellow band" injectors on most of the 117" builds we send to him. www.joescyclerepair.com
Thanks both for the injector info. I see some won't work with stock ecm? I have a tmax now, so I guess that needs to be taken into account as well. Amazing how critical all this stuff gets. If the pressures not up to spec everything goes for a crap at the top end.
Still don't know how many ponies the narrow belt can stand?
Ron
Ron
I don't know about the thin belt but, my 2007 Ultra has 170+ hp and 190+ tq and surprisingly I haven't had any problems with the belt. I had a 2003 Electra Glide Standard w/106 ci and a turbo that broke three belts before I converted to a chain.
I'm using the "stage two" injectors from www.injector.com . I have a client that is using the Thundermax and has the same stage two injectors also with one of my nitrous kits.
I sent my crank to darkhorse to be welded,balanced and new rods,I am not getting the timkin bearing done,my 113 engine will be mainly for touring on my roadglide not drag racing,so I think the stock bearing should be fine,from what I have read the weak link is the crank so I figured I should address this problem at the very least.
CDN. RG, skyhook: In all reality I don't think the stock roller is as bad as it's made out to be if operated in a sane manner and capped at a realistic hp. Thing is, at least for me, going through all that work I will spend the extra coin on the bottom end and hopefully never have to look at it again. I plan on keeping this one until I quit riding . The timkin is like piece of mind for me. Even though I just turned 56 my throttle hand reverts to an 18 year old occaisonally
Ron
Ron
