Winter tune
Winter tune
I'm going to have some work done on my bike this winter and wanted some feedback. I'm not experienced working with engines but I'll do my best to keep up. I bought this bike used this spring.
My bike has a SE Stage III 1550 kit with a SE 257 cam. I have the SERT and it was dyno tuned in 06 when the engine was done. After that, the baffles were cut in 1/2 (I assume to make it louder?). The service records indicate another dyno tune was discussed at this time, but it looks like it wasn't done. There is no charge for it and no hours associated. I assume they felt the performance was fine. The bike has V&N longshots and the air cleaner is nothing special. Sorry I'm not more specific on this point but the service records I have (25 pages) don't mention it that I can see. I asked my indy and he indicated it wasn't the best. Something like 2 1/4" paper filter?
This is my second Harley. My first was an EVO (93 Low Rider Custom) with only a Stage I upgrade. In my mind, the EVO had more pull. The bike was lighter and so was I so that may be all it was. However, I'm certain I should have more torque and HP on my Heritage than what it has for the work done on it to date. Unfortunately, the dealer didn't indicate the dyno results on the invoice so I can't tell where it was at.
My plan was to take it to my indy this winter and replace the cut down baffles with new ones. It doesn't seem to have the back pressure it should. Get the bike more air with an improved air intake and then put it back on the dyno with the SERT to give it a better tune. My indy is suggesting replacing the cam for a Head Quarters 575. Cost parts/labour about $600 for the cam job. Would you guys agree with this direction? What about this cam versus others? Would you do anything else while in you're in there?
Thanks for your ideas.
......I also agree that a cam made more more low end engine power will also give you benefits, but the gearing on your bike is poor and should be changed out. It will make all the difference in the world.
Gearing is a real plus, but the 3.15 is not all that bad compared to what those of us have on our 07 an 08 bikes - 2.79 final drive, but if you are primarily an around town rider with not a lot of long trips at 75 mph plus, gearing will make the bike much more responsive. I do like the HQ cams, but you need to find out what the compression ration is now of your build and what heads and pistons were used prior to just saying you are going to go with the HQ 575. There are so many variables that what you call a HD stage III kit could have different heads and CR's depending on the choices of components when the engine was built. Once you determine the build specs, the best cam for what you have can be determined.
The primary may be compensated for a bit though by the new 6 sppeds gearing setup. Most likely first gear is a bit steeper to compensate for it a bit, but still, these newer bikes feel like they are geared poorly if you ask me.
What is the best way to gear down on an 07 Dyna? I've read about the front primary gear swap.
16546-99 1550 CONVERSION KIT
16952-99C KIT, CYLINDER HEAD
17997-99A QUICK INSTALL PUSHROD
22868-00 SE TC88 HC1550 PIST
25155-00 SE 257 CAM KIT
32076-04 KIT, COMPRESSION RELEASE
32753-01 CYLINDER BASE COLLAR
37951-98 DIAPHRAGM SPRING
Your EVO had more pull because it was geared for more TORQUE output at the rear wheel. Your current ride is geared for EMISSIONS, LOL, and passing them. It has a poor 3.15 primary gearing ratio setup stock. Want to do something VERY WORTHWHILE to your ride over the winter? Change out that primary gearing to 3.37 or 3.48 and watch that bike come alive..............
