Mount Fatcat Ghost Pipe on'03 Road King-HELP!
I just bought a Fatcat and their ghost pipe for my '03 Road King and have no idea how to mount the ghost pipe. It had a Pro-Pipe on it so I'm wondering if there are some original parts that are gone that are needed to mount the ghost pipe. I bought the hanger for the rear end but I can't find anything under the seat to mount to. Is there supposed to be a bracket of some kind there that maybe I'm missing?
The guy at D&D was NO help at all. He said there are no instructions...
HELP!
Rick
HELP!
Rick
Yep, sounds like you might be missing a bracket (P/N # 65988-98, not nessessary for a 2 into 1 exhaust). If yours mounts like my E-Glide there should be a triangular looking bracket mounted under the two starter bolts that the stock RH exhaust pipe bolted too. That's where the front part of my ghost pipe bolts on, then under the lower bolt of the LH swingarm bracket, then the two bolts under the saddlebag.
VicW.
VicW.
MANY THANKS!
I figured there was a part that the other owner must have taken off when he put on the Pro-Pipe. Looks like I'll be heading to the Harley store.......How do you like the Ghost Pipe? I thought it was a great idea since I wanted to run a 2 into 1 on my 117" engine, but I like the look of duals on the RK Classic.
Rick
Rick
