Stock headers with slip on's vs True duel
Old 10-13-2008, 07:34 PM
ECSTREET08's Avatar
ECSTREET08
ECSTREET08 is offline
6th Gear
Default Stock headers with slip on's vs True duel
I have stock headers with slip on Reinhart mufflers on 08 street glide. Is it worth the expense to change to true duels and will I get more hp. I'm also looking for just a bit more volume on the pipes. I've been told by several that the stock headers with the crossover is the best setup.
Old 10-13-2008, 08:09 PM
Jeepin_Lawyer's Avatar
Jeepin_Lawyer
Jeepin_Lawyer is offline
Please do a little research (not being a jerk just giving you a heads up), this is covered weekly on the board. The short answer is: you will lose lots of low end torque with the true duals (I have the dyno to prove it). A 2-1 system will make the best power and the stock pipes with some slip-ons are a great (and cheap) compromise.
Old 10-14-2008, 08:40 AM
GliderXXX's Avatar
GliderXXX
GliderXXX is offline
You also might find that "Good" slip on's are so close to 2-1 performance the only reason you might want to change is if you like the look of 2-1. True duals will hurt your low end.
Scott Adams
08-24-2017 12:06 PM
Crusher
11-01-2007 11:42 AM
fiddlinfool77
03-31-2007 05:33 PM
GliderXXX
08-24-2006 01:40 PM
GliderXXX
08-21-2006 02:26 PM
Quick Reply: Stock headers with slip on's vs True duel
