Dieseling problem
RE: Dieseling problem
Yes, I would be concerned. Dieseling is tough on the rods/bearings etc. as it means the engine is "firing" when it is not in the right position to do so. The fuel is being ignited by hot carbon on the piston tops and/or combustion chamber.
Better fuel will help the situation. My bike specifies at least 91 Octane. Regular in most places doesn't cut it. If you can't get premium, maybe carry a small bottle of octane booster.
Also it may be running a bit rich which would cause carbon build up.
Hope this helps
Hope this helps
Thanks and it makes sense.I have in the past used octane booster .I have only recently noticed it so,I guess the thing to do is carry a bottle of booster in my bag.It does and always run rich.The S&S carb is an old one and I have tinkered with it at times and it just runs better this way.Better than too lean .Gas out in Texas small towns can be pretty crappy.
Throtle plate open too far. I have seen this way too much most times the guys had a low idel due to mis jetting and bumped the curb idle , but if the plate is open too far the bike even after shut down will suck enough air to draw fuel which gets lite in the hot chamber.
