hpi sucks (in a good way!)
finally put the icing on my year-old build:
08 fxdse 110"
r&r stage 4 heads
se 257 cams
hpi 55mm throttle body
se injectors
wood 3.25 a/c
10.7 compression
supertrapp supermeg 2 into 1, 28 discs closed
power commander
stock pistons, jugs, clutch
model 250 dyno, recently updated
old run differences: se a/c...stock tb & injectors...21 discs closed
shoulda done this a year ago!
08 fxdse 110"
r&r stage 4 heads
se 257 cams
se injectors
wood 3.25 a/c
10.7 compression
power commander
21 with open end cap , not 21 with no end cap, sorry I didn't make that clear. It does make a difference, and keep trying more discs if nessessary. And also dont get too hung up on #'s , how does the bike ride with the bigger tb on? You sounded thrilled until you read the sheet, I am going to try 62mm on a 103, sometimes the sheet does not tell the whole story.Hope you get it to where you are thrilled again!
johnnycondo
01-10-2015 09:29 AM
Russbucket
Exhaust System Topics
06-01-2010 03:07 PM
