Throttle & Idle Cables for S&S Carb...
Old 03-30-2005, 09:55 PM
TxMoores's Avatar
TxMoores
TxMoores is offline
Default RE: Throttle & Idle Cables for S&S Carb...
I received a not so nice email back from The Cycle Shack basically saying that I got what I ordered and it should work (based on the model and carb) and if it doesn't I am SOL unless the manufacturer wants to deal with me directly. I spoke with Magnum Shielding and had copied them on the various emails and they were more than willing to exchange the cables, as long as mine were still unused and in 'new' condition. Not a problem as I have the bike torn down repainting the tins, frame, etc. and the bike is not running. I used a piece of thick string last night and determined the travel needed will pass this on to Magnum Shielding, along with my carb model / series number to prevent others from having the same issue.
Old 03-30-2005, 10:49 PM
pococj's Avatar
pococj
pococj is offline
Received 1,297 Likes on 484 Posts
Sounds like time to cross Cycle Shack off the list of good parts joints. Ya ever wonder if idjits like that figure out what damage can be done to their reputation via the internet?
Old 01-17-2006, 01:21 PM
fxstcguy98's Avatar
fxstcguy98
fxstcguy98 is offline
I know this is an old post, but I think I can shed some light on this for others that may be getting new cables. S&S carbs did a change over at some point for the older bikes and added a bracket that allows you to use your OEM cables instead of the S&S cables. If your S&S carb has a tall cable stay (like and 1 or more) you need OEM length cables. If it has a short one (like 1/2" or so I don't have it in front of me right now), then you need S&S length cables. Hope this helps someone.
Old 01-17-2006, 04:56 PM
OG_electra_glide's Avatar
OG_electra_glide
OG_electra_glide is offline
not to beat an old post, but on my 99 night train with the S & S Super E, we only installed 1 cable. The spring on the throttle is so much stronger than stock, there was no need for the return (which was too short anyway).
Come to think of it, my mechanic scrapped the S & S cables and used one of his spares.
9192daveyc
Carburetor Related
02-06-2013 05:59 PM
haroldson
Shovelhead
11-25-2012 07:47 PM
capstone
01-20-2011 10:02 PM
champ198
11-02-2010 04:47 PM
rgm
04-21-2008 02:11 PM
Quick Reply: Throttle & Idle Cables for S&S Carb...
