Andrews roller cam conversion help
I am about to do the Andrews roller cam chain drive conversion.
When I took out the old Cam Plate, I did not align the cam marks before removing. Just pulled it out
Upon reading the instructions, I saw:
4. Before proceeding further, put the transmission in 4th or
5th gear. Remove both spark plugs so there will be no
resistance from compression pressure. Now turn the rear
wheel and align camshaft timing marks. This will simplify
installation of new cams.
Can someone tell me what I need to do to proceed?
2005 Twin Cam 88
thanks in advance
2005 Twin Cam 88
thanks in advance
