Exhaust, 2-1 or true dual
I went with the rinehart true duels because I have a 08 egc, I like people to hear me on the road when I am coming, plus I like the look on a bagger. What ride do you have ?
That is one consideration but not the most important . I understand 2 into 1 pipes are easier to tune for great results.
Fishfinaddict out.
Fishfinaddict out.
I have an Electraglide standard. Stage 1 kit thats it. Plan to do some mods this winter like big bore kit and cam and wanted to start with a good exhaust and tuner. I like them loud too and I was looking at the 2-1 Thunderheader. My friend has one on his streetglide and sounds sweet. I was also considering True dual Rineharts but real pricey. Heat is a problem for me because I'm short and my legs hug the crossover...hot...I don't know if heat is the case with the 2-1 but I know thr true duals resolve that issue..So many choices..drives you crazy!!
For some info, take a look at this: http://www.rbracing-rsr.com/
Especially if you're going to do a build.
There's a lot of good information throughout that RBRacing site.
The (unconnected) dual exhausts tend toward favoring mid-to-high rpm power generation at the expense of the lower rpm ranges. A connected dual exhaust will drop that favored area to the lower ranges at the expense of the upper ones.
A 2-into-1 exhaust can work extremely well everywhere.
I believe most (true) dual exhausts "come on" just fine by the 3-4k rpm range.
true duals
I put a set of true duals on my 04 Electra Glide and the loss of power was really noticeable, I removed them after two days and went went back to the stock crossover and Kirker pipes, sounds good and works good. Also I do not expect a HD to perform like a crotch rocket but as I said it lost enough power as to where I missed it.
This is just my experience and may not hold true in all cases however I hate to see anybody spend that amount of $$$ and be disappointed.
G@@D LUCK ! ! ! !
G@@D LUCK ! ! ! !
