rejetting
rejetting
has anyone tried cv carb rejet suggestions found in this forum using the washers under main jet needle and changing to 45 or 46 slow jet.have 05 carbed deuce and stock slow is 45 was going with big radius and high flow ness big sucker.assuming i would do the 46 slow and shim the main anyone tried this any info would be appreciated thanks
RE: rejetting
Every one has a different way. I have a 195 main and 48 slow, stock needle no shims. Got V&H bigshot staggard and S.E intake. Get 48 miles gal. 2 up. Plugs look very light tan. No flat spots. 25000 miles. Let dealer do it at 1500 miles with first service just to keep warrenty nice and simi legal. Had to repull carb my-self next day as it was not fitted correctly in rubber boot and was sucking air. Checked jets and needle just to make sure they were ok. Last time its been in shop!!! Did a friends Wideglide last year same way no problems.
RE: rejetting
I did exactly what you're talking about with the addition of adding a true-dual exhaust (05 FLHT). Before the change, the bike surged and popped through the carb (definitely lean) after the change (Big Sucker, Wild Pigs, Fullsac Dual kit, #46 slo, drilled idle mixture plug and two brass washers under the needle) she runs like a totally diferent beast. No more surging or popping, plenty of pull, great idle and an excellent sound - cwo
[IMG]local://upfiles/3599/45B952BBAA3141A5B433FCD720644288.jpg[/IMG]
RE: rejetting
ORIGINAL: deuce31
I posted that info as a result of trial and error over many years and it works well. I have used it on many bikes to date and most will agree that for the cost of about $5 compared to the $70 ++ for a jet kit, it can't be beat. Just don't drill the slide.
RE: rejetting
Not to hijack your tread(this is sorta the next question anyway's,lol) but I was just wondering what everyone is doing with their jetting when doing a 95" with say tw-37 cams,F.T. pist and minor head work with .030 hg? I had too also done the std carb changes with the A.C and pipes. Now with more C.I. is it nec to do a min of #195mj,#48 sj and more shims under stock or the Sportster needle? TCSTD any suggestions? This in on a 2000 Deuce with Supermegg. Thanks guys,Al
CSS_FXD
08-17-2014 01:56 AM
