Air Filter Question
Old 07-25-2008 | 01:58 AM
tjmoening's Avatar
tjmoening
Default Air Filter Question
I have a carbed, 05 FXST (Softail Standard) that has Hooker Staggered straight (no baffles)&nbsp\\;pipes on it. Is there anything I would have to do to the carb, or anything else, if I wanted to put an aftermarket air cleaner kit on it? Would it be a&nbsp\\;"take off the stock air cleaner and bolt on the aftermarket air cleaner" type job or is it more complicated then that?&nbsp\\;Would the performance be noticeable?&nbsp\\; Any help is very much appreciated!&nbsp\\; T.J.&nbsp\\;
Old 07-25-2008 | 01:21 PM
Doc 1's Avatar
Doc 1
Default RE: Air Filter Question
The bike will have more power due to more air entering the cylinders however the AFR will get leaner so the carb will need jetting.
Old 07-25-2008 | 02:01 PM
glens's Avatar
glens
It will have more power or merely be capable of it if the jetting were corrected?
Old 07-25-2008 | 02:11 PM
Doc 1's Avatar
Doc 1
Figure it out Mr engineer....or with your experience on Harley's you should know that answer.
Old 07-25-2008 | 03:02 PM
glens's Avatar
glens
I do know it, but your answer seemed a little vague, possibly misleading. Just wanted to give you a chance to clarify. Within current posting limits, of course.
Old 07-26-2008 | 12:20 AM
tjmoening's Avatar
tjmoening
Do you guys know if most after market air filter&nbsp\\;kits come with the proper jets for the filter kit, or are these something a guy would have to pick up seperately?&nbsp\\; Also, am I right in assuming that the idle would have have to be adjusted since there would be a large air-flow increase?&nbsp\\; Thanks for the help.&nbsp\\; T.J.
Old 07-26-2008 | 01:12 AM
ngoti8tor's Avatar
ngoti8tor
No the air filter kits do not come with any jets.
HardLuck71
11-24-2022 06:20 AM
d24112
EVO
07-12-2016 07:56 AM
Traxxtar
05-06-2015 08:27 PM
Javieret
05-07-2008 02:35 AM
powerpro509
04-11-2006 07:03 PM
Quick Reply: Air Filter Question
