RE: why does Rinehart 2-1 uses JAMES exhaust gaskets?
Either there or online like J&P, Dennis KIrk, and others that I cant think of. Depending on where you live it may be just as easy to go to moco and get the SE ones
I just installed the Rinehart yesterday. \\; The part of the header that goes into the exhaust port seems to be longer than stock. \\; The Screamin Eagles should work just fine.
I put a set of Screaming Eagle gaskets from the get go.
They work just fine. I usually tighten to specs, heat cycle
the bike a few times, then re-tighten everything but with
5 more pounds added to service manual specs.
