carborator backfires
my brother runs a 110 revtech and a 40mm mikuni carb, Arlen ness Vstack, with \\;martian brothers \\;(daisy cutter) \\;exhaust. \\;\\\\\\; I have cleaned the carb 2x's it is spot less, put in new plugs, check the wires, check the coils, added baffels for better back pressure... it is all spot on and he keeps getting a backfire out of his carb when he comes off the throttle hard... any ideas? I am gong to try to set the needle back another clip and see if that helps if not i am thinking the accelorator pump is off...
[IMG]local://upfiles/26534/DED7398A199B4CC385F3A7C103B7EAFC.jpg[/IMG]
