Front cylinder running hotter then rear?
RE: Front cylinder running hotter then rear?
Glens, at the risk of admitting my ignorance, yes, my measurements were taken to the left of the spark plug on both cylinders. \\; Which means it was on the exhaust side on the front cylinder and the intake side of the rear cylinder. \\; I'm assuming from your line of questioning that the exhaust side will be hotter. \\; Now I have to recheck my readings making sure I'm on the same side (in relation to the exhaust) of each cylinder. \\; I'll let you know.
Thanks! \\;
Thanks! \\;
Try to achieve perfect symmetry with the gun in relation to the cylinders, too.
I like to line the gun up along the cylinder bore axis and get a reading from the base of the sparkplug. The reading will be affected by stuff behind the target spot, if there is any, so take that into consideration.
10 degrees is less of a difference than I have seen. Usually at least 30 unless just coming up to temperature. Using Fahrenheit scale.
You should stop by the thread in the Electrical/Ignition/Tuner/ECM/Fuel Injection forum where they are talking about the Nightrider O2 IEDs. They were taking measurements much like you were. I tried to tell them about that and much more. They do not want to hear it...
