Sponsored by: Jekill and Hyde
My numbers
Old 08-11-2008, 04:45 AM
towboattrash34's Avatar
towboattrash34
towboattrash34 is offline
Originally Posted by Colonel Sanders
If it doesn't make power with the R&R welded heads then you can bet your **** that the tune is lame (which it is, btw.) Excellent heads.
yes i know the tune is lame,but i do promise to get a good tune either with TNT Performance or 1 other place/40 or more runs not the 4 i got. should be around the 12th/14th of next month. i'm also going to try to get a set of 2>1 pipes also. steve is also setting them up incase i want to change cams to the 9B all i have to do is just change the head gasket and the comp will be right
Old 08-11-2008, 08:49 AM
new_mentor70's Avatar
new_mentor70
new_mentor70 is offline
ive heard the Woods 9 is sick, very explosive power, good luck and keep us posted.
Old 08-11-2008, 10:16 AM
Colonel Sanders's Avatar
Colonel Sanders
Colonel Sanders is offline
Lightbulb
If you want to stay with 2-2s without sacrificing power potential, you might check out the Hooker Troublemaker line like I'm running. My 98" (525 cams, 9.8:1) made 112/112 with 'em and the 124" makes 137/134 with the same pipes. These pipes break the rules regarding 2-2s not performing.
Old 08-11-2008, 05:28 PM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
LOL I agree those pipes have broken the rules!!! I can think back to telling you that I did not think those would work well on the 98 I was wrong, then I said it again as far as the 124, no way that it would make the power on an engine that large.....wrong again!!! LMAO What else can you say, Wrong and wrong again.
Old 08-13-2008, 09:29 AM
Colonel Sanders
Default Good Hookers
Yeah, and how many people do you know that run 'em? No one around my neck of the woods. I have literally NEVER seen another set of these pipes on the road. They seem to be very unknown.
Old 08-13-2008, 11:49 AM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
Well Towboat is taken care of. He is getting a set of welded heads to replace those he currently has. CS knows the power they can make and this should top off his engine very nicely. Looking foward to seeing the new numbers. We are setting the heads up to accept the 9 cam at a later date, at this point he will retain the current cam. With a simple head gasket swap, and new cams he will be ready to roll. He is out on the boat right now not sure if he has a lap top on his boat or not???
Old 12-15-2008, 04:49 PM
NCTURBOS's Avatar
NCTURBOS
NCTURBOS is offline
Any updates...?
K.
onaride63
11-22-2010 03:17 PM
monkish
11-17-2007 07:38 PM
draycer
09-21-2007 11:13 AM
allen.m
01-27-2007 12:38 PM
HDWRENCH
10-25-2006 07:16 PM
Quick Reply: My numbers
