Gas tank leak and pressure
I've had my duece for a little while now and when ever I fill the tank all the way up and let it sit i get a small stream of gas coming out from underneath the center cover. \\; The other thing is that after I ride for a little while or the bike sits in the sun I seem to get quite a bit of pressure built up in the tank. \\; So I crack the gas cap open and release it about everytime I get on the bike. \\; My question is that I'm wondering if there is supposed to be a pressure release or a vent tube somewhere on those tanks. \\;
Thanks
Thanks
RE: Gas tank leak and pressure
Stock caps are vented. \\; Check you vent tube (comes off the front of the tank) to see if it is clogged first. \\; Try someone elses gas cap and see if the problem persists. \\; If it leaks out from under the dash you could try putting a new rubber gasket in there with new screws.  \\;
