mikuni or s&s
RE: mikuni or s&s
your cv carb will be more than adequate if jetted and tuned properly - give you the best mileage and excellent street manners.
if you have to change carb styles, i would vote for the mikuni. \\; \\; if you leave your motor stock, you will not see any significant improvement with changing carbs (over properly jetting, etc the cv you have) other than perhaps quicker throttle response. \\; \\; \\; not much improvement for the money spent.
RE: mikuni or s&s
I replaced the CV with a Mikuni HSR42. Much better throttle response, but you can spend less money and rejet the CV if you aren't going to change exhaust, cams, etc., what will give you a better response too, as not as much as with the Mikuni. S&\\;S carb is a great carb too and I love the look of its filter.
Javi
Javi
