Installing slipons, Should I use Silicone to seal connection?
I bought a set of used slip on Rush mufflers and gonna put on the Rg. Should I use new muffler clamps and install some HI-Temp silicone around the mufflers where they slip into the headers to help seal the connection and make sure they dont leak? \\; If I put the silicone on there what condition will the silicone be in 5 or 10 thousand miles if I pull them off to replace with sometrhing else?
I've never done slip on's before. Thanks HMT
RE: Installing slipons, Should I use Silicone to seal connection?
 \\; \\; \\; \\; I put on a set of Rush's a couple of weeks ago with new clamps. \\; I had leaks. \\; I pulled them off and use permatex copper silicon. \\; Try to put the adjuster away from the slits in the mufflers. \\; No problems now. \\;
